car alarm to stereo
for the audio to work you would need the radio to be on so im guessing thats not gonna work
but the gas door, im assuming you have an electrical switched door, if you have an extra aux button on the remote press it and find the wire that gets a momentary 12V then just wire that to the + on the door popper
thanks for the help, the gas door seems pretty simple to do i guess
you have 5 pins on a realy. the should read 85, 86 87, 87a and 30. on pin 85 put a 12 volt constant. on pin 86 put you - aux out from your alarm. pin 30 would be the ing wire to your radio, pin 87 would need to be 12 volt constant and pin 87a would be your ign from the factory wiring harness. also you need to make sure that your aux out from your alarm is "latched" meaning it will stay on and not just pulse a negative.
yeah i need to know how to set my aux channel to be "latched" its a viper 5900 btw, my car is a 2000 lincoln town car.
pontiac_rayzer
pontiac_rayzer
DALLAS TX
Mtrhd329
