can you bridge a 4 channel amp
it's pretty easy. Let say you bridge the amp. You will 1 rca out from the deck (any). Then you'll have a right and a left rca. On the right one, you'll put a Y to get 2 rca from the same left and then you plug them in the respective channel. Check the amp manual to see how to bridge it. On mine, channel 1&3 were bridged toghether. You'll see it when plugging the second rca in the amp, it will get louder with the same gain.
You do the same for the right and then set you amp with a dmm coz the gain isn't really accurate and it can goes from 200 to 350 watt in a matter of little degree.... you don't want to be sending 3x rated power + clipping... that would be fatal
Maybe if you spent less time being a jagoff and more time using the site for what it's supposed to be used for you'd know.
Agreed. And don't you (OP) have enough posts asking this question yet? Hook it the eff up and find out. And keep using the internet for **** instead of asking the same simple, searchable questions.
endofdays89
Banned
endofdays89
missouri
Xprime4
