Can the Mach 5 Maw 12s
r0ck
can the mach 5 maw 12s...which are dual 4 ohm be wired down to 2ohm load using autotek MM1400.1 (its ??
these are the specs for 1400.1
650-Watts RMS x 1 @ 4ohm
1000-Watts RMS x 1 @2
1400-Watts RMS x 1 @1
I have been only able to find two wiring diagrams. either @ 1ohm or @ 4 ohm. (i've been told not to run it at 1ohm..cause the amp wont be stable at 1ohm)
So i wanna run it at 2 ohm..which should be give my 12s plenty of power.
can someone help me out plsss?
Yea you need an amp that will put out 700wrms at either 1 or 4 ohms.
Sell me your opti2000d...it would be perfect //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I need it for when I get my second sub //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
r0ck
r0ck
DFW, TX
ultimate157
michigan born
    May 14, 2026
michigan born
    May 14, 2026
