digital mint
Open up
What would be the outside dimension of a 4 cu. (tuned to 30 if that matters) ported box? i have to see if it will fit in my trunk. thanks
Thanks, What i have to work with is 17.5-18 high and about 33" wide. Possible?Couldbe any combo of dimensions. What's the space you are dealing with? Yes, tuned to 30 matters cuz then you have to include port and sub displacements so you will be looking probably around 4.5cf before displacements.
thanks, Now i need a plan!What depth are we talking? If you use 17.5 tall by 33 wide by 17.5 deep is ~4.6cf so if you have 17.5" to deal with depth wise you should be good to go. Now just design an enclosure!! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
16x16x31.5 = 8064I'm probably wrong, but I think that's around 7^ft
Acorrding to a little thing I used to use, until I found out it was somewhat inaccurate
Anywho, you should have plenty of room to do it, just keep in mind that you have to have some way to actually get it IN the trunk, unless you plan to build it in there![]()
GotchaI'm probably wrong, but I think that's around 7^ft
