rival904 10+ year member CarAudio.com Elite 947 0 my house Aug 15, 2009 #1 And also let me know if thats enough port area for a 12in RE XXX, sub firing forward, port firing up. Thanks Click to read more...
dappa5 10+ year member DO WORK! (if u can) 1,858 0 S.W.FL Aug 15, 2009 #2 which side is bottom and where do you want port?? what size sub??
OP rival904 10+ year member CarAudio.com Elite 947 0 my house Aug 15, 2009 Thread Starter #3 The "Height 1" is the bottom, think of a wedge box for a pickup truck. Its for a 12in RE XXX, new style
dappa5 10+ year member DO WORK! (if u can) 1,858 0 S.W.FL Aug 15, 2009 #4 what's the mounting depth and where do you want the port /?
OP rival904 10+ year member CarAudio.com Elite 947 0 my house Aug 15, 2009 Thread Starter #5 Mounting depth is 12.75 And I want the port on the "height 2"
dappa5 10+ year member DO WORK! (if u can) 1,858 0 S.W.FL Aug 15, 2009 #6 there is no port but specify where you want and i'll model it in not sure there is enuff mounting depth though
dappa5 10+ year member DO WORK! (if u can) 1,858 0 S.W.FL Aug 15, 2009 #7 there is not enuff mounting depth are these your max max dims??
OP rival904 10+ year member CarAudio.com Elite 947 0 my house Aug 15, 2009 Thread Starter #8 No, my max demensions are H - 25.5 Wdth - 58 Max Depth at the bottom - 16.5 Max depth at top - 10
dappa5 10+ year member DO WORK! (if u can) 1,858 0 S.W.FL Aug 15, 2009 #9 No, my max demensions are H - 25.5 Wdth - 58 Max Depth at the bottom - 16.5 Max depth at top - 10 Click to expand... well its that ratio of 10 top and 16 bottom thats killin you you should try a trunkated style sub need to lay down a bit more
OP rival904 10+ year member CarAudio.com Elite 947 0 my house Aug 15, 2009 Thread Starter #10 What you mean? I thought about doing a long, skinny box, thats shallow, and just invert the sub and the ports. What you think?
MakeshiftAudio 10+ year member AudioRx 1,805 0 Oklahoma Aug 15, 2009 #11 That sketchup isn't even right for what the table says. Anyways, you can't just calculate a box volume then plug it into the port calculator, because the port itself has displacement, and will decrease box volume. UNLESS you use an external port.
OP rival904 10+ year member CarAudio.com Elite 947 0 my house Aug 15, 2009 Thread Starter #12 Right, I understand that the tuning will be off by a little bit. Either way, I just want to fit this big *** sub in my truck lol
dappa5 10+ year member DO WORK! (if u can) 1,858 0 S.W.FL Aug 15, 2009 #13 The "Height 1" is the bottom, think of a wedge box for a pickup truck. Its for a 12in RE XXX, new style] so why is it wrong? Click to expand...
dappa5 10+ year member DO WORK! (if u can) 1,858 0 S.W.FL Aug 15, 2009 #14 it may be possible with those dims but the sub wil be @ bottom of face not centered
OP rival904 10+ year member CarAudio.com Elite 947 0 my house Aug 15, 2009 Thread Starter #15 With my idea, I could center it between the seats.
