Can Someone Please Check My Box For Me?
  • 5
sml238
Ok well I started building a box but before I glue and screw it all together I want to make sure im 100% correct.
Box dimensions
H = 16.5"
W = 43"
D = 17.25" (That's including the double baffle)
Port dimensions
W = 4.5"
Port L1 = 10.5x15" (The port length is really 12" because the double baffle adds 1.5" to the port length
Port L2 = 4.25x15"
Can anyone tell me my port area, tuning, and box volume after displacing the port?
My goals are
- 4 net cubes
- 36hz
EDIT:
Here's a pic of my box so you can understand how my double baffle is. See how both baffles are on top of the port making it 1.5' longer.
Your box will be 4.5ft^3 tuned to 35hz not counting in speaker displacement.
i got 36hz. how come u got diff? did u understand about my port length and everything?
and will a 45 angle piece change the tuning?
my speaker is .23 and the angle pieces will take up about .15. so my box will be about 4.1 cubes.
Your well within recommended specs for your Audioque. 4ft^3 ported is perfect.
Just don't get too crazy with your power and listen to your sub. She will tell you if you're over working it.
ok thanks. but you think it will be alright? it should actually be just about 4 cubes even after all the angle braces and ****.
but i was thinking. after my sub is in the box and i add the angle cuts. thats going to raise my tuning wont it?
should i make the second port length like 4.5" or 5" to keep the tuning at 36hz?
The design that you have (Or the one I gave you) Had all the angle's accounted for in volume. Even if you don't put them in there they take up so little of volume that it is not going to be a change in tuning
Still not convinced? https://gpcaraudio.com/15-dual-high-output-glue-it-screw-it-sub-enclosure/ You can order the box glue and screw kit with...
15
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
sml238
sml238
Southwick, MA//Providence, RI
mikey7182
    May 24, 2024
    May 23, 2024
