Reg cab S10 boxes
Um, I did a box for my budies 03 regular cab s-10. Did 4 12" kicker CVT's. Very tight on space. I believe the box was 8.75 inches at the bottom, 3.5 inches at the top, 16 inches high, and I believe it was 52inches long
Hmm.. any perticular setup your wanting to do? In a truck like that it would seem more logical to use shallow mount subs cuz I know there isn't enough depth for a sub like in your avatar. My 97 GMC sonoma whish is pretty much a S-10 has(did have) a blow-through. I went through all kinds of boxes behind the seats. Never found what I was looking for so I cut it up. But then I sold it //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i used to have a reg cab sonoma, i had 4 10"s in a box that was 51" wide, ~21" tall, 4" top depth, 10" bottom depth. it took up a ton of room, and still wasnt really enough airspace for 4 10"s sealed. I would suggest a box with a bottom depth around 7" and top depth around 3", 51" wide, and maybe 16-18" tall. that should be enough for 2 nice 12"s
I want to fit the two Mach 5 SPL-12s behind the seats.. i was thinking external aeros between the seats
how deep are those and what kind of box specs?
Features
Extreme high power, high output subwoofer
Designed for SPL/SQL performance
3" dual 2 Ohm high temperature voice coil
Thick pulp cone with foam surround
Solid pole
Triple stacked 8.5" magnet structure
6 layer spyders
2,500 watts RMS thermal power handling
can withstand burps of up to 8,000 watts
Shipping included in price
(within North America)
Power Handling - 1,500 watts daily usage; 2,500 watts thermal
Sensitivity - 90.5db (2.83 volts)
Impedance - 2 + 2 Ohm
Recommended Box Sizes
Sealed - N/A
Ported - 84 litres (3 cu. ft.) 36Hz tuning
Competition - varies with vehicle and install
T/S Parameters
Fs = 42.9 Hz
Re = 3.8 Ohms
Qes = 0.32
Qms = 2.35
Qts = 0.28
Mms = 258.5 g
Rms = 29.6 kg/s
Cms = 0.053 mm/N
VAS = 14.1 litres
Sd = 433.7 cm2
BL = 28.7
Xmax = 17 mm
I don't have the stock seat, I'm currently fabbing up some brackets to fit 1st gen Prelude buckets in it. I don't care if it comes up past the window line.
These subs have no pole vent also, so... they can be close to the back wall.
Any ideas anyone?
I'd do a blowthrough but I don't know if the gasket is re-usable. I will have to pull the bed off to fix the fuel sender, and eventually will have to pull it off to install bags... so I don't know if I can re-use the accordian gasket..
Any ideas anyone?
buy 2 of them
Gearstix
Gearstix
Alberta, Canada
Gearstix
