Fattony911
Dual 2 ohm voice coil
Die cast aluminum
Metal-flake Royal Blue Finish With Diamond Cut
Non-pressed paper cone
Chrome finish front & back plate
Large foam rubber surround
1-piece rubber gasket
Black spider
Woven tinsel lead through spider
Chrome screw terminals
2000 watts power handling
800 Watts RMS
200 oz. magnet size
2.5” ASV voice coil
SPL 93 dB
FS: 29.1 Hz
VAS: 4.73cu.ft.
QMS: 3.83
QES: 0.457
QTS: 0.4986
XMAX: 0.6"
Sealed box: 2 cu. Ft.
Ported box: 3 cu.. Ft.
Tuning: 35 Hz
Port Size: 4”x6.25”(diameter x length)
# of ports:1
which one of these is driver displacement????????? please help
Die cast aluminum
Black spider
800 Watts RMS
200 oz. magnet size
2.5” ASV voice coil
SPL 93 dB
FS: 29.1 Hz
VAS: 4.73cu.ft.
QMS: 3.83
QES: 0.457
QTS: 0.4986
XMAX: 0.6"
Tuning: 35 Hz
# of ports:1
