can someone check my math please(gain/dmm)
Thank u all very much! Now about that loudness button... The speakers have a lot more bass response and are still very clear at high volumes. I've read on here to not use that except for low volumes but I've also read it will change the voltage to your amp but when I tested it on/off the amps output voltage stayed the same.
Loudness can be fun to be played with at moderate volumes. Just use it with caution it boots the high and bass frequencies. Do not set your gains with loudness on.
Ok. I checked the deck and loudness was on so I turned it off to set gains but voltage was the same. I also hooked up the speakers to see if a load on the amp would cause voltage to differ and that also stayed the same. So I adjusted bal to right side by 1 on hu and got my voltage at 17.3 right side and 17.2 left side on volume 45. Anything else?
Skoty422
Skoty422
Louisiana
Skoty422
