Can someone build me angled speaker rings?
ghart999
I need a pair of speaker rings to hold a pair of 7" midrange. I need them at an angle since they fire very low if using regular rings. I have no idea how to make them with a router if that's even possible. If you can and would, please PM me or reply here.
What I need is 3/4" mdf ring that has a linear angle from the 3/4" at one down to 1/4" at the other end.
Outer dimension is 7" and inner dimension is 5 3/4"
Thanks all.
You could "try" cutting out the rings with a router, then marking your taper and use a hacksaw to cut em. Little filing/sanding and they should be fine.
Not sure how easy that would be, but it should work as MDF cuts pretty easily. I'm assuming you'd be sealing them to the doors with rope caulk or something, so they wouldn't have to be perfect.
ghart999
ghart999
Denver, CO
WantedIsHere
