Can my car handle this system?
jmw703
I'm going to be installing my brz1200.d. Amp into my 2008 Mazda 3 soon, I had some questions about the electrical.
I don't want to have any light dimming or anything I just want to know if my car could run this amp as well as another 4 channel amp without problems
4 gauge power and ground for amp
Upgraded battery
Will run at either 900@ 2 ohm or 1200 @ 1 ohm with the gained turned down a bit ( sub would be 900rms , what would be better ?)
stock alt is 90 amp I think.
In the future I would add a 200 watt 4 channel amp
Do I need big 3 or anything or could my car handle this
big 3 is always good to do. Set your gain with a dmm not just turned to where you think it should be. Also that amp will probably not do rated. You may have some dimming you never know...
jmw703
jmw703
louisville, ky
Vossy
