Can my car handle this system?
  • 4
jmw703
I'm going to be installing my brz1200.d. Amp into my 2008 Mazda 3 soon, I had some questions about the electrical.
I don't want to have any light dimming or anything I just want to know if my car could run this amp as well as another 4 channel amp without problems
4 gauge power and ground for amp
Upgraded battery
Will run at either 900@ 2 ohm or 1200 @ 1 ohm with the gained turned down a bit ( sub would be 900rms , what would be better ?)
stock alt is 90 amp I think.
In the future I would add a 200 watt 4 channel amp
Do I need big 3 or anything or could my car handle this
big 3 is always good to do. Set your gain with a dmm not just turned to where you think it should be. Also that amp will probably not do rated. You may have some dimming you never know...
I know how to set my gains.
And I know it's overrated but not by much.
I just want to know what I can get away with before I start to see problems
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
862
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
164
A Link would be very helpful. Id be interested in taking a look at some gear
183
629
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
jmw703
jmw703
louisville, ky
Vossy
