Can I wire a single cap to two amps without a power block or ground block?
acribb
I have a 2004 BMW 530i that has a 2 amp setup. I noticed that the current draw is VERY slightly dimming my tail lights when the bass hits hard. I think a capacitor would easily take care of this. I don't want to spend a lot and just want the capacitor. I currently have my bi amp system wired directly to the battery (which is thankfully in the trunk). Since I am not trying to show the system, do I really need a ground block or power distribution block? Is the one fuse I have in the diagram below enough, or should I add an extra fuse on each 8 gauge run from the cap to the amps? Thanks for any advice...
Lose the cap, it'll just hurt you. Get an extra battery.
you guys want him to spend 2-300 bucks on a new battery when hes only running 500 watts? that sounds pretty stupid to me.....
either keep the cap or do the big 3 that everyone is talking about.....or you could just ditch the factory subs and just run the 12w3......
might want to get check grounds make sure they are good and see if you have to replace your battery anways....seems to me a bmw would have a stronger alternator.......
I replaced the factory amp which drives the factory subs underneath the power seats with the Profile. You can't really replace the factory drivers as they are under the seats and of course a special shallow size. The sound is many times better with my aftermarket cheap Profile amp driving them.
With that said, will my proposed setup in the diagram work? Do I need a fuse block, power block, ground block? Since we're not talking a lot of wattage here, please let me know if the 1.2 cap will work with both my amps. Why would it not be a good idea to install the cap? How could this 'hurt' me?
If I do need the power block, fuse block, and or ground block, can you recommend any cheap places on the web?
I wouldnt do any electrical upgrades for that lil amount of power...if ya want get a better battery up front and that should easily cover it
But this is just me...good luck
you guys all ignored his question tho.
No I didn't.... if the wire size changes, then he needs to fuse it... I mentioned a fuse block as it's much easier and likely cheaper than 2 new inline fuse holders for his dual 8g wires.
I do find it hard to believe someone's driving a 5-series BMW and is too cheap to properly protect his investment.
To the OP... search in the OT forum for the burned-out VW and you'll see what happens when you try to take short-cuts. :S
acribb
acribb
Jacksonville
alex6999
