Can I run my subs off of different amps?
I still would not recommend using different amps.
You could set the gains with a tone at X input voltage, so you get Y voltage. Music being dynamic and each song is different, who's to say both amps will have the same amplification curve (don't know what to call it).
Say you set them for 500 watts with a 4v signal. Turned down daily around a 2v range, one amp could be putting out 200 and the other would be making 250 watts. Also, less significant, but the damping factors wouldn't be the same.
What if crossover slopes weren't the same? Say one amp has a 12db rolloff and the other has a 24db rolloff.
Say one amp clips way sooner than the other.
Plus, it's ghetto. It's like running two different subs on a mono amp, which we never recommend.
Diff amps being utilized...try and keep up.
If you weren't so busy changing names and creating another account, you'd know what's going on in this thread.
There will be no difference. The ducking amp does the same power at 1ohm as the 2 amps will at two ohm. Not to mention I doubt he can properly set it up
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
09VIC
09VIC
Atlanta
Papermaker85
    May 31, 2024
    May 24, 2024
