not really. you have to have the power to charge those batterys so if he like only plays his sub for half the time he drives then yes but other wise he needs more alt powerOne more C&D and you should be straight....
Just throw them on a charger, is all you have to do. The batteries will get ran down yes and the stock alt will not recharge them that fast. If you did not bump your system for a few days they will come back just fine.not really. you have to have the power to charge those batterys so if he like only plays his sub for half the time he drives then yes but other wise he needs more alt power
agreedThey can be ran @ .5 ohm but I don't see why you need to every day. I would just run it at one ohm. If it was for competition, I would say go for it. But you don't need to push your amp and your electrical to the limit every day. You need a bigger alternator. Adding batteries works just fine but you need the amperage to back them up.
