Can I run 2000RMS with just a front battery and a new alt?
Based
Louisiana
Can I run 2000RMS without putting a second battery in the back? I don't want to put a second battery I'd like to keep it just to one battery, and changing my 90A alt to a 200 - 270A (whichever works) alternator.
I'm looking at the Kinetic 2000, or the Deka 31.
yes you can, but use a deep cycle battery with that big alt, the bigger the alt more quickly your battery will be recharged, but if you are listening to music with the car turned off the battery will discharge quicklym so is better if your single battery is a good one..
Would you have any recommendations? And I've read that deep cycle batteries are not good for a car's main battery....
Here was my last setup...
240a mechman alt
Duracell G34 (55ah)
DD m3a wired at 1 ohm nominal
The lowest drop I ever saw (not at idle... don't play at idle) was from 14.4 to 13.9. It usually dropped to around 14.2 at the lowest unless I played below tuning, that's when the bigger drops happened.
I have a singer 240 amp alternator with the big 3 and right now just the crappy stock battery in my lancer and I run a 3000 rms amp at 0.5 ohm and I hardly go any lower than 13.5v when I have it turned up.
Mist stock electrical system can handle 2k fairly easy. But you having only a 90 amp alt would prolly have a hard time. So the sky the battery and a big 3 kit. And you'll be golden
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
Based
Based
Louisiana
phemps
