Can I ohm a single svc (4)ohm down to 2 ohm?
Hi,
I'm new here. I was just trying to get the most out of my set-up. I have a kenwood kac7201 amp and a 12" eclipse sw6123.4 sub. The amp is 230x2 @2 ohms and 460w x 1 @ 4ohms. The reason why I'm asking if you can ohm the sub down to 2ohms is because 460 is too much. It's a 250 rms sub. And the other setting 150 x 2 at 4 ohms is too little. Butttt I have an eclipse ea2000 that does 175 watts at 4ohms. But the kenwood pounds harder at 150watts than the eclipse at 175w. Why is that? Is my set up safe?
Thanks for your help guys
its not too much. you can bridge that amp to that sub at 4 ohms and keep the gain on the amp turned down so the sub never sounds "stressed" when playing
it should hold up fine
its actually better that way. you are not asking the amp to make 100% of its power all the time.
imagine driving your car every day every where you go with your foot all the way to the floor / shifting at redline lol
its not good for amps to do that either
haha
Ok I'll try that. I have it hooked up to a computer power supply unit. Janky... I know. But when I briged it I thought I heard a pop in the sub and the system (psu) turned off. I was too scared too try to turn it back on. Do you know how to set the lpf better. Like is there something I can buy off here? I can hear voice through the sub even with the lpf on and the he set all the way down.
---------- Post added at 11:00 PM ---------- Previous post was at 11:00 PM ----------
Hz set all the way down I mean
Ok cool I'll set it back up briged. I'm excited because it pounds at 150watts. I just thought 460 would be too much for a 250rms sub. Thanks for your help I know you guys know what you're talking about.
460w is too much for a 250w sub - but the gain control is ajustable so you can set it at the max level you listen to to only give off 250w or maby a tiny bit more to your sub. - but if you just crank the gain setting all the way up then yes it will be too much and you will probly burn out the sub eventually... but before this happens the sub will play and sound stressed = your warning sign
Tyrionmanister
Tyrionmanister
Columbus, Ohio
brian84corvette
