sicilianiggy
To make it simple my amp is 4x60 on 4 ohms or 4x120 at 2 ohms. My front speakers are components rear are coax. All 100w rms and all 4 ohms. The setup don't sound to loud. Can I run these at 2 ohm?
How would the components be wired in order to be bridged?You can try bridging your amp to the component speakers. This will give them more power and keep your soundstage up front. If you want to keep the back speakers for rear fill, power them off the HU.
Yea I know that , but I meant I dont have to 're wire anything? What about the rears tho? I only have one amp?Your amp has a line connecting the + and - terminals that's labled bridged. Hook your front left speaker to the positive and negative terminals that are labled bridged and your front right speaker to the other one labeled bridged.
Ok sorry for all the questions. I'm just a beginner and wanna get a good idea. So bridging the front will give me 120@2ohms even tho the speakers are 4 ohms and it won't do any damage? What about setting the gain? How would I figure out the voltage needed? Is it now Wats x 2 ohms squared? Roughly 8 volts?The rewiring that will be needed is wha Da64u explained in his illustration. The connections at the crossovers for the components will remain the same. You can run the rears off your HU, in that case you would need to run the speaker wires for the rear speakers from your stereo. I run only front speakers and it gets plenty loud for me.
It is exactly as bbeljefe has pointed out.Ok sorry for all the questions. I'm just a beginner and wanna get a good idea. So bridging the front will give me 120@2ohms even tho the speakers are 4 ohms and it won't do any damage? What about setting the gain? How would I figure out the voltage needed? Is it now Wats x 2 ohms squared? Roughly 8 volts?
So the rears are mids? What exactly is a mid?Your components should be reproducing both midrange and high frequencies.
