can i install home sub into Car??
akballow
I was wondering if it is possible to connect a home Sony 8inch Subwoofer with a 100watt amp built in to my car audio system. My head unit came with a front and rear pre-amp output. if i connect my Home Sub to the power supply via a cigerat outlet, will i be able to connect the Sub to one of the Pre-amp outputs.
If not is there anyway to add my Home Sub to my system?
Since the Sub has a Build in amp it should get a small kick, nothing fancy, but just for the small extra base?
iam just so ghetto, but i am low on cash, and i have this sub and iam bored. sorry for the multiple threads, i thought they were not posting so i tryed diffrent channels. :C sorry
you will not be able to plug a 120 volt powered sub into a cigarette lighter. the power inverters in the lighter are not enough. you'll need a power inverter plugged directly to the battery.
akballow
akballow
los angles
phyphoestilic
