Camaro speaker set up help amp
Eteam
Hello I wanted to know what amp I can use for this set up? Sepperate amp for the subs. and how would I conect the amps to the factory chevorlet 2014 camaro my link? And how would I connect the 4 tweeters to the amp?
2xFront door https://www.sonicelectronix.com/item_43396_Rockford-Fosgate-Power-T1675.html
2xBack deck https://www.sonicelectronix.com/item_19510_Rockford-Fosgate-Power-T1693.html
1xFront deck https://www.sonicelectronix.com/item_19529_Rockford-Fosgate-Punch-P132.html
4xTweeter https://www.sonicelectronix.com/item_43390_Rockford-Fosgate-PP4-T.html
2xSubs Rockford Fosgate P3D4-10 Punch P3 DVC 4-Ohm 10-Inch 500-Watt RMS 1000 Watts Peak Subwoofer by Rockford Fosgate Amazon.com : Rockford Fosgate P3D4-10 Punch P3 DVC 4-Ohm 10-Inch 500-Watt RMS 1000 Watts Peak Subwoofer : Vehicle Subwoofers : Car Electronics
If you're going to run coax in the front and 3 way in the rear, there's no need for 4 extra tweets. If you're going to keep the stock hu, you need a line reducer, or LOC. You'll have to tap into the stock harness to find the front and rear speaker leads so you can add the loc.
You will wire the tweeters to a 2 or 4 channel amp just like the door speakers. Make sure you know how to set the hpf and do it right. If you don't know how read up on it. If you aren't going to run a 5 or 6 channel amp, then I would definitely recommend using a separate amp for the subs. And you need a line out converter to convert the high voltage signal that comes from the factory radio down to a lower voltage that the amps can safely use. Some amps come with spots to wire high inputs directly into them without a converter. It just depends on which amp you end up using
if you have the my link then you might also have a factory amp that you will need to bypass. Depending on what 4ch amp you go with you may or may not require an loc. if the amp has high level input then you could achieve the same thing by using the high level input.
Eteam
Eteam
Miami
CrossoverOre
