Calculating output wattage at 4 ohms
  • 2
You'd need to measure the current to know for sure. Since it's 2,500 at 1 Ohm and 1,700 at 2 Ohms it's safe to estimate ~800-1,000W at 4 Ohms. Are you trying to set your gain with a DMM?
I was trying to see if I could use this amp at 4 ohms to safely power a pair of Memphis HPO10's.
I know how to set gains with a DMM, that's not a problem. I just wanted to see if the 4 ohm rating would be close to what I'd want to push those 10's with.
I had to look up that sub and I couldn't find official specs, but it seems that amp may be fine with 2 HPO 10s.
Yeah, the amp should have plenty of power. I'll be starting a build log sometime in the next two weeks.
92
Which amp and which speakers? What crossover are you using? You may be fine so long as you never push the volume too hard.
T.I.K.
F*ck it, we'll do it live
T.I.K.
Michigan
T.I.K.
    May 16, 2024
    May 16, 2024
