My rubi2500 is only given a rating down to 2 ohms, and I was wondering if there was any way to calculate the amount of watts it would produce at 4ohms.
You'd need to measure the current to know for sure. Since it's 2,500 at 1 Ohm and 1,700 at 2 Ohms it's safe to estimate ~800-1,000W at 4 Ohms. Are you trying to set your gain with a DMM?
I was trying to see if I could use this amp at 4 ohms to safely power a pair of Memphis HPO10's.
I know how to set gains with a DMM, that's not a problem. I just wanted to see if the 4 ohm rating would be close to what I'd want to push those 10's with.
