Cadence Q7000M vs Rockford Fosgate P500X1D
  • 5
dev199505
US
Which would you guys reccomend I like Rockford but I like the beefy look and orange and black color scheme of the cadence. I know Rockford makes good amps and are underrated. But how does Cadence hold up against them?
Sent from my HUAWEI Y536A1 using Tapatalk
Cadence is like boss I think
Not even close. The Prime series is the worst series Fosgate makes. The Cadence will shit on that Fosgate amp. If you look at the internals, its built closer to a 700wrms amp would be. I have used Cadence in the past with the PX series and their older Z series. I have never seen a Cadence bench less than what they were rated for.
The Cadence is 110 and the Rockford is 130 but a lot smaller but pushing close to the same power
Pick which ever one fits your budget, goals, etc. I would personally would pick the Cadence.
So between the Cadence ($110) FSD ($120) and Rockford ($130) which would you chose for the HDS215d4
I was trying to push him towards that new fsd 700 rms amp for 120
That fsd is probably pretty comparable to the sundown 600 it's more than likely top tier of your list
Sundown sae 600d solid amp
Fsd fz700d look similar?
Cadence has 2 20 amp fuses sundown sae600d 2-25 amp fuses fsd 700 2-30 amp fuses according to amp draw if the fsd is as close to as efficient as the sundown it will have greater output
If I go with the FSD Amp I'd have to buy the D2 version of the sub which could make finding a replacement amp hard if the FSD ever blew out
First of all you would want to verify that it works. Next, don't expect to get much out of it. There's a rather finite life expectancy on...
Get your Coupon RIGHT NOW!!!🥳🥳🥳 Let’s celebrate the upgrade of Cadence Sound Website! Take this chance to get the 10% OFF coupon which has no...
849
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
dev199505
dev199505
US
dev199505
    May 31, 2024
    May 24, 2024
