C5-653 install help
stroberts22
KY
I'm having trouble with my JL C5-653 3 way component set. The vehicle is a 05 Dodge Ram 3500. My setup is alpine CDA-9887 head unit feeding into a Audio Control EQL then to a 300/4 v2 bridged to the C5-653 component set. The sub amp is a 500/1 v2 fed from the sub output on the 9887 going to a single 12w3. I also have a set of vr525 cxi in the rear doors fed from the built in amp in the 9887. I just got the C5-653 hooked up and found out that one of the 6.5 was already blown on the right side. I sent that speaker back for a replacement. I replaced it temporary with a old 6.5 MB Quart and finished rta tuning the system. I noticed that there was a dip on the right side at 315hz was the only problem I had with the curve but when I combined the 2 channels it went away. It sounded great but yesterday I noticed a 4" mid on the left side wasn't playing. I thought I blew another speaker but this time it was the crossover that was the problem. I got the gains set after equalizing at 24.4 volts ac on the 300/4 v2 with the head unit vol at 30. I have never had this much trouble with a car audio product. What am I doing wrong? Is this a common problems I'm having? What can I do to avoid this again?
I don't understand why you would need an Audio Control EQL when you have a CDA-9887. Doesn't it come with a built in EQ? Why don't you just go 3 way active? maybe add another small 2 channel amp for the tweeters.
The 9887 has a 5 band parametric eq or a 7 band graphic eq but I can't figure out how to adjust each channel separately so I installed the EQL. The EQL got the frequency response adjusted easy with both channels adjusted independently and then combined. I would like to go active but don't want to get the system more complicated than it already is. Does the passive crossovers always give this much trouble?
stroberts22
stroberts22
KY
stroberts22
vegang
vegang
