C2 Audio Dethcon subwoofers
Thank you some one said it. OP what is your budget how about that and how much space do you have?
Between sub and box I would like to go no more than $500, less is better. As for space, well I know that cubby will go at least 2 cu ft. If the box can be built taller than flush or maybe even outwards a bit then a good 2.5 easy or more. I know that would accompany most 12s
[quote name='Steven2002']Between sub and box I would like to go no more than $500, less is better. As for space, well I know that cubby will go at least 2 cu ft. If the box can be built taller than flush or maybe even outwards a bit then a good 2.5 easy or more. I know that would accompany most 12s[/QUOTE]
Don't know what you mean. What vehicle? What are your max measurements. Build your own box, 99% of prefabs **** have @dbeez ; make you a design.
Wouldn't recommend every one run them on 1k but I have seen it done and it was a nice surprise.
I ran a 12w6v2 on an MTX 81000d for quite a while.
I would agree, with a good box and tuning, it is a very pleasant surprise. Great output and maintained outstanding SQ at any volume.
[quote name='Silverado SS']Don't know what you mean. What vehicle? What are your max measurements. Build your own box, 99% of prefabs **** have @dbeez ; make you a design.[/QUOTE]
Well its a transam so its gona be a odd ball design but id say u can get 2.25 cubes while staying flush in the ttop hole
Car is a 2002 ***** Am. 2 cu ft minimum 2.5 can be done, maybe even 3.0 cu ft max
Steven2002
Magnolia, Ar
Steven2002
