BXI 1606 Gains
Gotcha. That seems okay. You can try turning off the subsonic filter. And maybe try turning the lowpass up a little. Like maybe to 90 or 100 or so.
Also, just another thought. Are you sure the speakers are wired correctly? I'm just trying to think of reasons why the subs aren't as loud as you say they should be.
Do you have them wired like this, or in some other configuration?
hahah dang. i just pushed the crap outa my sub today.
the box jumped around while bumping the lows of 'the cuase of death' - immortal technique
probably had some sub damage.. but still good. xD
BXi1606d >>> S12L7
yes, they are wired like that just one question how would you split the wire right here
what hu do u have?
and if you have a box lol.....u should have two terminal cups on it correct? if so just run posititve to positive and then negative to negative on the outside then just run a positive and negative to the amp. but make sure the subs are wired like they are suppose to be ....and on the inside of the box just run the positive to the positive and the same with the neg.
hahah dang. i just pushed the crap outa my sub today.the box jumped around while bumping the lows of 'the cuase of death' - immortal technique
BXi1606d >>> S12L7
did you smell the voice coil smell, if ya did then theres a chance that sub was beggin for mercy lol if not give it more
yea but i have to run a 2 pos and 2 neg one to each terminal, so do i run 2 speaker wires out of the amp or just one and the split it to two
Two speaker wires out of the amp would be better, it will split the load between the two wires. If you were to run one wire to one terminal cup, and then just "jumper" over to the other one, then all the power would be going down the one wire from the amp.
hahah no smell =p but i only let it bounce for like 5 seconds. i blew a 8w7 in 2 weeks =x.. didnt want to do that to my second sub...but of coruse i had an underated amp. rf t3002.
vewbvye818
vewbvye818
ny
Frijoles24
