Burned Coils
dking_boss
i have or shall I say had two Orion HCCA dual voice coil 4 ohms subs wired @ 1ohm to and Orion HCCA D5000, 2500w rms and 5000w peak. Everything was working fine for the longest after I got my car from the shop from getting somebody work done, two days later the coils were completely burned. I don't have a clue as what could have done this, any help is greatly appreciated.
Clipped ? Yes your subs must have blown because your amp lacked power... the body shop probably messed up your grounds..//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
921
Deff be a disaster and quite a shame blowing a freshly repaired amplifier in a few min.LOL. Id be very upset for sure. id recommend the wiring...
23
Lower the ohm the thicker the wire. The higher the ohm the thinner the wire but will have more windings. Lower ohm coils have a slight edge when...
dking_boss
dking_boss
Sierra Vista, AZ
pawn man
    May 24, 2024
