Building box tommorrow..Need Advice
sfniner415
So I just got in my new 10" Arc Audio D4's and wanted to build a ported enclosure for my single cab truck but I need advice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The box dimensions are:
Width: 50
Height: 17
Top Depth: 5
Bottom Depth: 8
Ports are going to be: 3" round and 15" long and will be on each side
Tuned Fq: 32Hz
So with my calculations that should give me 2.175^3 to work with.
I plan to use 2 seperate chambers so that the box will be stronger.
I'm going to goto lowes tommorrow and plan on purchasing:
- 3/4" MDF
- PVC pipe (for ports)
- 2" drywall screws
- Panhead sheet metal screws (1/2" and 3/4")
- Carpenter's glue
- Silicon caulk
- Non-hardening rope caulk
Am I going to need anything else and am I going to need the brace the box some more or will that be enough?
Thanks
You don't need 2" screws, they will just be easier to split the wood with. Get 1 1/2" at most.
For woodglue use Titebond II, it is awsome...
If you don't have a countersinking bit, I would get one. Things go much smoother when you predrill your holes and counter sink. Also, a pair of corner clamps will come in handy //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And just take your time, patience is a virtue and will bring on success.
Crap, I forgot to add the 3/4 MDF that I'm going to add to seperate each chamber for bracing....So that means I have to subtract .75 off my internal volume to get my actual internal volume now right?
btw, would that be enough bracing for a box that big?
thanks
will I even need to brace this box or should the 3/4 MDF be enough? If I do need to brace it, should I just put a solid piece of MDF in there in order to make it 2 different chambers or should I cut holes in it for air to pass through?
Thanks
To give you guys a visual:
I know its not the greatest but //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Anyways, I just wanted to know if thats gonna need bracing because if so then that throws everything off because I got into take the brace dimensions into factor for my actual internal volume and change my port length etc.
Thanks
Might want to do a brace in the middle . The front back and bottom are pretty long . //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
But you wouldn't need anything large , could use a piece of 1" dowel connecting the front and back , and a piece connecting the top and bottom . Should suffice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah thats exactly what I was thinking but should I put a solid piece of MDF in there? Or a MDF piece with holes in it to let air pass through?
If I make it 2 different chambers, each chamber would have see .9 cubes and the port size would have to be rediculously long and I already got the precision ports which have a max length of 17 inches //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
The other problem with putting holes in the brace I wouldn't know how to account for the brace's dimension and it would throw my port size, tuned fhz and everything off //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
Any suggestions? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah I might have one or two //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif If you have scrap mdf , you could use it for bracing as well . Cut like a 3" wide piece long enough to reach from the front to the back you would loose 3 x however long x .75 (width of mdf) /1728 = cuft you would loose for that piece of bracing. Do the same with a piece connecting the bottom and top //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sfniner415
sfniner415
San Francisco
Pyro_By_Nature
