ok...I started building a box for a tacoma truck. I will be using 2 8" subs that sound and perform best at around .7-.75 cu ft on a vented box. So I am guessing 1 big box that will house 2 speakers at around 1.5 cu ft would suffice for 2 8's that require that...correct?
I calculated the box to be actually around 1.9, but still have a couple things to factor in such as speaker volume and a small brace etc that will take up volume as well.
Now....the question I have is on ports. On a dual sub setup that shares the same air space...what is the best way to go about porting this? I dont have much room for long ports, so is there a min or max number of ports one should install to get the required tuning frequency, or does number of ports matter? I know diameter and length play a part...just wondering if there is a certain number of ports u should have per speakers, etc.
