build ?
People on here frown on it but I have done it in the past and I got to say it did slam for what it was but yes it won't hurt anything as long as you know your final ohm load.
Generally when you have different sized speakers you want to cross them over so they don't try and play the same frequency ranges...
12's and 15's have no problem covering the same frequency ranges so i'm not sure what logic would cause that response. There's nothing wrong with it although it's typically not done by a legit shop or installer. It should basically sound just like 2 15's would, if not a bit louder. I would put them all on the same amp if you can line up the impedance to make it work so you're not having to match level's. But all in all it'll work, you'll just get a lot of people on here frowning on the idea although it can work just fine.
it'll be loud but it'll sound funny, i've tried multiple size setups before, sound quality takes a huge drop regardless of the countless box experiments i did. But it will be louder than just 1 15.
If you do it make sure they are in the same enclosure and on the same amp. Otherwise what the above poster said will happen.
In some of the experiments they were in the same box and they have always been on the same amp, always have phase issues when running multiple sub sizes, generally not worth it, he should sell the 12s and get a matching 15 instead or vice versa
Independently, yes. I didn't say they weren't capable of playing the same frequency ranges, I said you wouldn't want them to.
Nutdawg651
Nutdawg651
bubbagumper6
