Build serio help???
Sorry like I said I'm new to this and I haven't been looking at rating I been looking at 2000w+ mono amps gatta give me a break. Y'all haven't trown any name brand amps y'all just gave me power give me good recommendation amps and I can start looking there I got a good 500 dollars to spend on a amp even more if it's worth it.
You said no budget,so kinda hard to narrow it down
If it were me, I would choose between the crescendo bc2000, or the soundqubed sq2200, both are workhorse amps decent prices. you won't be disappointed with either of those. There is also an american bass hybrid 4488, that would more than satisfy you and those type x's. The most important part of it though, is the enlcosure, it can make or break your system. Those subs can do work in a sealed enclosure, but they would literally blow you mind in a custom built ported. And, you will need to up your electricals, as previously stated, to thuroughly enjoy what ever you end up with.
Yeah, I just wan tto do everything right money ain't the issue just need some help for my build
Then do the big 3 with 1/0 wire. Pull everything and install sound deadner, install an extra battery with relay, buy an amp with2,000 watts RMS, have a box builtfor your space and subs, have a pro install it. Then work on the frnot stage with high end componets and a clean head unit with a good amp
Type-x-kid
Type-x-kid
City of frogs
Type-x-kid
vegang
vegang
