Build recommendations to match subwoofer
mgiara
Hi,
Based on some quick research, I've decided I want to replace my '08 L7 15 with an Image Dynamics IDMAX 15 to retain and slightly increase power output and improve SQ.
I plan on purchasing the "stage 2" sealed box from zeeBay that's matched to the sub, and eventually adding a second.
What amplifier would you recommend pairing the sub with?
Also, I read in another thread that keep hope alive recommended pointing the sub towards the rear passenger corner from the trunk since I'd prefer not sealing off the rear seat-trunk opening.
Would I be okay doing so with this setup, and eventually adding a second to the opposite corner, also pointing towards the rear corner?
I'm seeing the following on the same auction site I mentioned above:
Sub $200 bracket:
Hifonics Zeus ZRX1216.1D
Hifonics BXX1200.1D
$200-$300 bracket:
Kicker 43CXA12001 (While I like its CEA-rated 1200 watt RMS value, I worry about the 2400 watt max output causing harm to the sub)
Rockford Fosgate R1200-1D Prime
Memphis Audio SRX1200D.1
mgiara
mgiara
San Diego, CA
mgiara
BP1Fanatic
BP1Fanatic
