Build Log: rtillaree's 626
well the deal about it is, im going to be making a custom interior, so you wouldnt see whats there anyway, so even if i left it all seams, you'd never know...even though on the 2nd layer your going to be hard pressed to find black or seams, i've got some ideas in mind for the cuts and such...
update 6/6/2007:
nothing real major, however i did finish the majority of the floor and i started on the deck lid...i have a little bit of trimming to do around the base of the spare tire area, once that and the deck are complete i will start on the quarter panel walls, i figure that will be the most difficult based on area to work in and cuts...
for the deck im making specific cuts and then covering them over with and entire sheet
got a little harder to work with using a template
more to come tomorrow...
thanks alot...im kind of trying hard to make sure it goes properly and im trying to squeegee out all of the wrinkles and bubbles...as long as it sounds good im straight...
small update, finished a few more areas up, also have completed 3 layers on the floor, so if your counting at home that is 135mil across the floor, i will most likely do that on the side walls as well...
only real problem i had is i lifted the deck today and one of the pieces had fallen off and another one was loose...not sure what the deal is, i put up a few more pieces to see if it was a one time thing or what...going to have to wait and see...
god i cant wait to be done with this already, taking me forever it seems...but with the time i have it's just not a realistic thing to have it done quickly, plus slow and steady wins the race, right...
if anyone wants to come by and help me run some wires and such, do a big 3 with a hard to get at alt and mock up a box for the hc2400's holler at your boy
rtillaree
F***, Strong
rtillaree
Orlando
rtillaree
BP1Fanatic
BP1Fanatic
