Build log: 4 WMD 12's
Q&A
Quality and Accuracy
We are doing a new build featuring 4 2009 WMD 12's with 1,500 wrms on tap per sub.
8 cft birch plywood enclosure with 6 - 4 inch aeroports tuned to 40hz
The 4 12's come to a 1.5 ohm mono load
Extensive internal bracing
Test fitting subs and port flares
What type of vehicle is this going in? I would think the optimal set up would be sub up, port back. Either way, it looks like a well built box.
2 more port assemblies are on the way, then we'll have all 6. When they get here it's test time. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I cant wait for this build I am going to try 4 of these in a sweet setup in trunk in my civic.you think 8 cu is to much i was going to go with 7.5 maybe 8 if i can squeeze it in there
Lovin it!! To bad Im too lazy to post up pics and vids of my 4 WMD2 10's. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ok i have to bite i want info specs and price of the amp it looks sweet
love the box i should put up some pics of our build but **** its not easy to do when its 42degrees f and 50 in the workshop building gets put way down on the list of things to do
xMplar
After the noise treatments in the doors, floor, and rear of the Camaro, I turned my attention to the firewall. These vehicles have a tube that...
40
6K
This build is more of a working novelty than a practical project. It turned out better than expected really. I'm going to make something similar...
18
Yeah we did that. We're stupid loud right now. Almost done just need the head unit.
60
18K
16
Q&A
Q&A
west coast
99grandprixGT
