Build enclosures
CSCStang aint answering me & said that he was busy with work a while hack. LolisaToop how much would you charge me to make a Wedge Ported box for 2 Sundown Sa8s
Try to get him to design it... then build it yourself, or, if your'e too busy or not mechanically inclined then have someone do it... once drawn up you will see just how easy it is, for years I did it by hand... A set of plans will take out the guesswork and make it something to go thru with... I drew some ideas, some plans but never followed thru. CSCStang worked out some plans on Winisd, showed me some response curves and after I decided on one he sent them drawings over and it is like a motivator once you have the plans. They looked so good and he punched them out so quickly I felt some compensation was earned. That's up to Ya'll but once he was onboard it was fast! My old box is on the block as we type...
i was being a **** to another form member but i can throw you something together with a cut sheet.. its an arm and a leg to ship a subwoofer box. unless you doing it with a CNC it cost an arm and a leg..
Come on man... Someone in the most populated state is avaliable... Try searching SPL on facebook then joining a group if nothing else... Lots of pros on the west coast!
I build enclosures! i can analyze your woofer calculate parameters shifts and build you a airtight box that is the best money can buy!plus i like guys so you in good already!
No you don't. You have nothing to contribute to this forum nor show for.
BassDrop
BassDrop
SALINAS CA
Boomin_tahoe
