Build a box for me $$
ok the price is good and the ^ft is that per sub after displacement and if for some reason 3/8" does not hold up what kind of warranty do you have for ur boxes i understand using under normal every day use i know i cant stand on the box
My warranty is I stand behind what I build to the degree the integrity of enclosure is structurally sound to withstand usage under normal conditions the enclosure is design for given the subwoofer being used in it.
If for any reason the construction of the enclosure fails to due inadequate fabrication, I will either replace the enclosure or refund the costs under condition of the enclosure has to be shipped back to me for visual inspection to determine if failure was caused by my hand or caused in some other manner and picture document the cause of said " failure ".
I will not merely take someones word that the enclosure failed and they want there money back without me see for myself what the problem is as to if I am at fault or not.
I will not stand behind what I just stated if the enclosure is damaged in shipping, that's why pay for insurance for every enclosure I ship to protect both me and the customer.
Thankfully, I can say that to date, I have never had a customer contact me due to an enclosure behind delivered in a damage state. I ship my enclosure's in double wall corrugated cardboard boxes I make myself from sheet stock cardboard and open cell foam blocking for the packing material.
But, I can assure you that when I build an enclosure, it will not come apart, at least not on it's own, I haven't had one fail yet out of the thousands I've built since 1995.
that sounds good to me. So as u stand now on this design this would be the finished product right? and also I do not need terminal cups on this enclosure. also with this port design what does that make the box tuned at
3/8" MDF exists? That shit would be PRIME for some home audio enclosures. Even .5" MDF chokes off small 2-3" drivers. Where could I gemme summadat?
As it stand now, that design is the finished product, unless you wish to change it.
That port is tuned to what you wanted - 35 hz.
Well, I get it my distributor over in Jersey. I would say that most lumber yards within your area are buying from one local distributor that handles a board regional area.
Also, you may want to looking into cabinet shops in your area and ask them where they get their sheet materials from.
Best bet would be to search the net for MDF Distributors in your area.
i may need to change the cut out for the fan but every thing else is just like i want
im waiting to hear back from the people that make the fan im going to get i will let u know this thing looks sweeeeeet
PM with particulars on ordering
How is this coming along?
His enclosure had to be trashed and is in the process of a new enclosure being built.
The reason for the enclosure being tossed is due in part that the wood glue I presently use ( I buy in 5 gallon pale ) is defective. The manufacturer of the glue had a bad batch run and was recalled after numerous other customers complained that the " bond " of the glue had " weak bond joints ".
And for the record and to squash any rumors.
This wood glue is not a retail available, it is only sold for commercial use: meaning it is not sold in HD, Lowes or any other store that sells wood glues.
I buy my glue thru my distributor where I buy my materials and this is my first time using this product and unfortunately this enclosure was first with this glue and thats why I trashed it and now I use only TITEBOND WOODWORKERS GLUE.
OUCH.
Man, I was looking forward to pictures of this. And the manufacturer's error means less profit for you on affected boxes you've built //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
OUCH.
There still will be picks of the build for this enclosure.
As for enclosure's built being effected by the " glue debacle ", this enclosure was the only one. I'm not that gullible though because with anything " new " I limit my " liability factor " by doing " test shots " which proved " favorable " in the " joint bond " so I only did this one enclosure with the glue and then that's when my distributor contacted me to inform me of the issue's other were having.
So, I'm only out what I put into this one enclosure, but, no other enclosure's were built with this glue, so, even though, I lost time and money on one customer it could of been worse to lose a sh!tload of time and money on alot of enclosures.
As for the money, my distributor made up for it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So, now all builds are to be done with TITEBOND, but this is only because I can longer find ProBond Woodworkers Glue where I used to be able to purchase it. I'll have to call Elmers to find out what retailers also sell it.
i dont like changing brands for that very reason
I only changed because I could no longer find ProBond Woodworkers Glue where I was able to buy it, but I called Elmers and they told me Ace & Tru Value Retailers are still selling it, I just have to call around to find what store locations near me may or may not stock it.
I'm not a big fan of Titebond wood glues only because some years ago their products had similar issue's and I'm not saying they do now, but, that is why I always used Elmers Wood Glue Products and if I can get Probond again, that's what I will build with.
Build Pic's:
http://s29.photobucket.com/albums/c251/MrCabinetry/Ranger%202%208w3v3%20Ported/
bad03ranger
Get Some *****
bad03ranger
Reidsville, North Carolina, United States
low00ranger
vegang
vegang
