Build a box for me $$
actually the port should take reference of the xmax of the driver and VAS of the driver as far as how much power..that would reflect on the size of the box.. and im not a bass head check my thread on diymobileaudio.com
The port does take into account the xmax, cone to excursion displacement and power = vent mach.
Now, way back when the arguments, debates and discussions were going on about vent mach, port velocity, laminar flow and all that good goofy business was " what is the acceptable ratio of air movement thru the port?".
The consensus was .20 meters per sec or 65 ft per sec, anything above those numbers was considered " too fa king high " which is total bullsh!t because that would mean the port area takes precedent over any other design element given the max size the enclosure cannot exceed or design limitations the enclosure needs to fit within the install.
However, conforming to the established " NORM's " means " one must adhere to and not deviate and anything other is subject to speculation ".
Specifications, Requirements, Fit, Function and Design = All Covered. Job Done.
Customer = The Final Word.
That box is going to slam and will keep bad03's legroom. This is something you rarely see in a regular cab Ranger - a properly specced and built dual ported box. I just wish I could hear it in person //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
bad03ranger
Get Some *****
bad03ranger
Reidsville, North Carolina, United States
low00ranger
vegang
vegang
