Build a $800 dollar system, what would you go with
Jimg
CarAudio.com Regular
216
13
I already have a Kenwood excelon 793bh head unit
it has basic time alignment. I can set separate tweeter and midrange crossover settings
so let’s spend $800 on the amp, speakers, and subwoofer
looking to have a set of tweeters. What would you use
a set of 5 1/4 front door speakers What would you use
no rear speakers
looking at two 8 inch subs. I want to go sealed on the box. I need to keep it small if I need to take it out
i would like to use a 5 changed amp, But I am also ok with a 4 channel amp and a separate sub amp if it would work out better
Tight, yes. But I think it can be done and still sound way better than factory
i am looking at tweeters in the $100 or less range
massive ct2 tweeters $75 is what I am looking at
5 1/4 size mids in the front doors. infinity kappa perfect $200
subs. In the $200 range. NVX VSW8,s. $100 each
amp. 200 range Rockville db55 is $180
i have wire and fuse, distribution blocks from a previous build
so can save the cost on the install
this leaves $145 to build the box, rca cables, other minor things that will be needed
Are there better options than what is listed above
I would go the Pioneer 8704 over that rockford all day long
Come with 2 Refurbished 10" Sundown SA V1 Rev 3 along with a Sundown SFB 1500.1 for 479.99 plus the 200 roughly for the pioneer you are at 680
You can then do Silver Flutes in the 5.25 that will be 50 for the pair
And then for the tweeters you have many options...The Alpines for 40 bucks shipped
Or a set of Massive CT2s
So if you went that route with the massives you would be at 825.00
With the Alpine tweeters you would be at 790 so 2 options.
Just equipment on the $800
I have a lot of the wire , fuse blocks , distribution blocks ect already
Ok. Well for $800 I have bought used and new. I have purchased Infinity Kappa 690csx (open box) for $180, Zapco ST4D for $150 for front stage. You can get a good setup for $800
Honestly, its harder in my opinion to get a lot of budget stuff because of the whole economy. A lot of stuff is out of stock because of everything going on with us and China
I just received the Dayton ultimax 8 inch sub in the mail. Really nice looking subwoofer. modeling software is showing that it is excellent for sealed applications. I’m using it in a 4th order bandpass due to its efficiency in that enclosure. Good xmax for an 8.
I would take NVX amplifiers over their subs all day long. Those have usually met or exceeded their RMS on dynos. Also yeah those Daytons in the 8s or 10s sound decent in sealed setups.
16
751
917
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
798
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
864
Jimg
Jimg
Jimg
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
