Budget friendly class D amps fsd/Crescendo ?
I just bought an fsd 2600 off a member here but haven't hooked it up yet. I've heard nothing but great things about them though. For a 4 channel I just received a soundstream tn4 900.4 which I got for like 120 I think? They're basically the same as the ppi 900.4 and ppi owns soundstream
Right now I'm strongly leaning towards the twisted sounds. Seems to be a lot of positive reviews from my research. Does any one know if the Crescendo symphony are the same quality as the rest of there line up.
Ok I'm trying to decide if I want to go with the twisted sounds or the FSD. The TS is rated @1800 @1 ohm and the FSD is rated @1600 @1ohm. I know they both seem to do rated power if not more. They seem to use the same board but I assume the others components of the amp are different? Do you guys think the T.S. will put out a noticeable difference in power. The fsd is $100 cheaper and so is the 4 channel so I would save $200 total going with the FSD. I know this is splitting hairs just wanted an outside perspective. Thanks for your time.
Those are nice amps however a little more then I want to spend and I would probably never use the crossover but thanks for the recommendation
Dan B
Dan B
Seattle
C1500martin
