Budget 10" or 12"
1990 Ford Bronco 2 this is a temp build to hold me over till I can afford a good build. Im currently running a 10" pioneer IB flat in my Ford ranger I've ran 8ohm kicker comp CVR in my old BMW and a cheap Walmart pioneer. I've ran old school 10" Rockford Punch subs and a pair of alphasonic alpha 400's in my old Honda accord. I wanna get away from mainstream brands like Rockford pioneer and kicker and try something new but at the same time want something that's tried and tested don't wanna go out and buy a sub that sounds like **** because it looked like a good deal
Sent from my HUAWEI Y536A1 using Tapatalk
300 bucks man you should probably keep saving man.... I have over 1k into my budget build on my Tacoma.... Fi ssd 10 fully built on a solid 1200 amp with box wiring and alt upgrade its 1k deep easily that's not including my DVD headunit all door speakers and amp for my speakers....
Eventually I plan on running a big system I just need something to hold me over till then
What power range do you wanna be in
Around 500watts will do for now I'll be on a stock alternator till I get a better job so can't run too much
I'm really liking the Rockford fausgate prime 500X1D amp I'm thinking about going with it and the E10 from Tom with a box built by CSC
You could do that orrrrrrrrr pick up a fi audio x 15 750 rms sub for 200 or a soundqubed hds315 or a hds215 both are under 200 bucks and solid budget bass woofers.... Then get a fsd audio fz1600 or 1200 or 700 the 1600 is 170... 1200 is 150... 700 is 120 on Amazon... They are Korean amps should be solid stout amps
With that low of power having all that extra cone area will make a huge difference still have the stang build your box he did great work with my one off enclosure
I could do that but then I wouldn't have the budget for a box. I also wanna stay with 10" or 12" and this is just temporary I may run bigger later on but for now I'm not wanting bigger than a 12" and the furthest I can stretch my budget is $400 for everything I've also seen videos on YouTube of the E10 and it looks like a really good sub.
Hds215 is 105 add the fsd fz700 for 120 now your at 225 you'd just barely go over your 300 mark
Wouldn't the Rockford amp still work fine for it? All the birth sheets for it are over 600watts rms
Still think the fsd would be a better option since it will probably dyno closer to 1k and after box rise give you full rated power to that hds200 series... Or a little extra
760
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
dev199505
dev199505
US
mrpep
    May 16, 2024
    May 16, 2024
