Looking for a budget minded 10" or 12" sub to hold me over until I can afford to build a good system I have $300 to buy sub amp and box right now
Sent from my HUAWEI Y536A1 using Tapatalk
Eventually I plan on running a big system I just need something to hold me over till then300 bucks man you should probably keep saving man.... I have over 1k into my budget build on my Tacoma.... Fi ssd 10 fully built on a solid 1200 amp with box wiring and alt upgrade its 1k deep easily that's not including my DVD headunit all door speakers and amp for my speakers....
Around 500watts will do for now I'll be on a stock alternator till I get a better job so can't run too muchWhat power range do you wanna be in
I could do that but then I wouldn't have the budget for a box. I also wanna stay with 10" or 12" and this is just temporary I may run bigger later on but for now I'm not wanting bigger than a 12" and the furthest I can stretch my budget is $400 for everything I've also seen videos on YouTube of the E10 and it looks like a really good sub.You could do that orrrrrrrrr pick up a fi audio x 15 750 rms sub for 200 or a soundqubed hds315 or a hds215 both are under 200 bucks and solid budget bass woofers.... Then get a fsd audio fz1600 or 1200 or 700 the 1600 is 170... 1200 is 150... 700 is 120 on Amazon... They are Korean amps should be solid stout amps
Wouldn't the Rockford amp still work fine for it? All the birth sheets for it are over 600watts rmsHds215 is 105 add the fsd fz700 for 120 now your at 225 you'd just barely go over your 300 mark
You could is it 1 or 2 ohm stable?Wouldn't the Rockford amp still work fine for it? All the birth sheets for it are over 600watts rms
