Broken Headunit??
  • 1
mumbling_joe03
8
Kansas
I have a friend with a ACD2900 Blaupunkt cd-player. She just wants to get it working long enogh until she can get another player. Here is the problem. I have checked the power and it's getting 12.45 volts power. The unit for some reason turns on fine and is pushing about 5.43 volts out the right back, left front and back speaker wires both positive and negative. The right front is only pushing 1.03 volts both positive and negative. This is the only thing that i can see that might be wrong. I checked the fade and balance and it's equal. The unit will not put out any sound:furious: //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif :furious: and it's ticking me off. I checked everything about 10000 times. Can anyone help me out??
Thanks
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
Sounds like it's the digitizer in front of the LCD panel (a separate clear thin glass panel that responds to touch) is what broke. Technically it...
5
OK, so turn your music on at moderate listening level and unplug the battery/alternator and see how long that capacitor keeps things playing...
19
what ^ said. amp gain setting info, test tones are at the very bottom...
459
mumbling_joe03
mumbling_joe03
Kansas
mumbling_joe03
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
