what do i need
  • 2
its not recommended to run that amp at 1.5 ohms, but it can be done. just make sure it has really good ventilation and if ur not cranking ur music all the time, it should do fine. to run 4 of them i'd suggest u get 2 of those amps. if u wanna play it on the safe side, get a 1 ohm stable amp, then u dont have to worry about heating problems.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
211
Thanks for your input! I did some research and wanted to share what I found for anyone else in a similar situation. It turns out that the Honda...
177
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
510
mario
mario
Tuczon, AZ
SuckMikeHawk23
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
