nicster 10+ year member
Hello,
I recently aquired a Legacy 300 watt 2 channel bridgable amp, and a jbl 10" loud and clear sub. I hooked it all up (I'v only done this about 4 times) and i go to turn on the sub and all i get is a little bit of vibration from the sub. A pretty low tone. Does anyone have a clue what might be the prob? This is for my brothers g/f So it was suposed to be under a 100(which it was off ebay, all new) I am using the high-inputs because of her factory stereo. Any help would be great.
Amp- Two Channel Bridgeable Output
2 x 150 Watts Total Output
1 x 300 Watts Output Bridged Mono
MOSFET Power Supply
Variable Gain Control
Built-In Subwoofer Crossover
Gold Plated RCA Inputs
High Level MOLEX Input
Speaker Impedance: 4-8 Ohms
Easy Access Speaker Connections
Soft Turn-On Circuit
Remote Turn On/Off
Thermal Overheat Protection
Speaker Short Circuit Protection
Input Overload Protection
Heavy Duty Aluminum Alloy Heatsink
Power On LED Indicator
Protection LED Indicator
Frequency Response: 15-30kHz
Signal to Noise Ratio: 95dB
Dimensions: 8"W x 2"H x 10"L
Sub - JBL LC-S1050W 4 OHMS, 400 WATTS PEAK, 100 WATTS RMS, SENSITIVITY 92dB, FREQ RESPONSE 38 - 800Hz
MOSFET Power Supply
Remote Turn On/Off
