websterbud
I have a Merlin MD41 4 channel amp that I'm bridging to run a set of components. The amp is rated at 180x2 @ 4ohms mono. I've read the gain setting turorial and there is a link to JL's site about gain setting. JL's site says that the impedance each channel works at will be 1/2 the load inpedance. Therefore it is necessary to divide the actual load impedance in half and use this impedance on the chart when bridging two channels. Also, the voltage found on the chart should be doubled. Then it gives two examples.
Just the simple sqrt(power*resistance) = voltage and I get 26.8 volts. Is this right? The way JL does it I would be setting my gains at 38 volts. A little help?
