bridged 2 ohm
If you want to join 2 speakers, you can connect them in series to double the impedance instead of parallel, which halves it. That's why some people recommend 8 ohm loads for a bridged amp.
your amp is 2 ohm stable in stereo and 4 ohm stable when bridged. you can put anything higher you want. you will receive no benefit in wiring two 4 ohm subs as 8 ohms for a mono load. just hook a sub up to each channel, if that's not enough power then you need a new amp.
so if i wire in series @ 8 ohms then bridge it i will have 4 ohms on each channel and it will work fine. am i understanding this correctly
Your amp is 2ohm per channel stable, so you can bridge it at 4ohm if you wanted too. But bridged @ 8ohm is fine also.
locedout
locedout
high desert,ca
squeak9798
