box
ok...i'm ready for sketchup;) here is all the measurements. its 37" wide(external) and there will be a 3/4 inch brace that runs down the center of the port and stops at the end. if i forgot something or something looks wrong PLEASE tell me:blush:
so i guess noones gonna sketch it....//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i guess i'll just have to wait till i build it:up2somet:
its prolly wrong. its very hard to sketch (on paper) somthing like that with human error.
thats why i always start with cad to begin with. jelly, PM me and ill get in touch with you about somthing.
hey the dimensions you posted have to be wrong. its not working out. maybe its just me.
they probably are. i didn't sit down and actually calculate the numbers. i just used a ruler:( being 1/4 scale i had to round numbers to the nearest 1/4 inch, give or take the width of the pencil line....which in my case is up to 1/2" (scale) in some spots:blush:
surprisingly, he was almost 100% accurate, but he calculated the volume wrong. and the 'baffle' where the subs are gonna be mounted was like 15.93" instead of 16 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
like i said, he was VERY accurate. and thats hard to do with pencil and paper. props jelly.
if the box is 37" wide, its just about 5.9 cubes. the tuning is closer to 25hz.
everything is just about dead on. angles are exactly as in your picture. if you want, i can dimension all the angles for you so you know how you have to cut them too.
and if i knew how - i could extrude this shape to make a '3d box' but i forget how that works. so feck it. //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
shit your right. i put in 130 degrees instead of 150. god dam spring break //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
jellyfish420
i design boxes .......
jellyfish420
STL ill side
jellyfish420
