Box tuning?
trevor87
I just picked up this box for free and i used tuning thing over on bcae1.
to find the tuning of this box using the external dimensions. But id like someone with more experience to double check the tuning for me if you can.
Its a slot ported truck box for a 10" sub outer dimensions are:
Length= 48"
Depth 1= 4.5"
Depth 2= 7.5"
Height= 14.5
thanks for any help
I know the outside port Length is 13" tall and the width is 2" but idk the length inside the box i measure where its mounted at on the outside and it looks to be 22" in length hope that helps
well how can i measure it when the box is already build and its a slot port with the port inside
It's really not hard at all. Just take a tape measure and see how long the first port panel is from the front of the box back as far as it goes. Then, measure how long the back port panel is (if there is one) by going through the sub cutout.
Without those dimensions, there is no way to know what it's tuned to. It's bullshit to guess a size and tuning. We also need to know how thick the wood is.
Since I'm pretty sure you're going to fail at getting and naming dimensions, I made an mspaint drawing to show you what we need to calculate the tuning:
Make sure to get the lengths of each of the colored lines. We also need the height of the port. Don't forget wood thickness.
Is this basically what it looks like (all of the dimensions are like you said)?
If so, then it is 1 cube tuned to 44hz. Once we have all the necessary information, it takes all of about 5 minutes to figure it out.
trevor87
trevor87
GEORGIA
trevor87
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
