Box size
  • 4
What size box and tune should I build for American Bass XO 12s. Either I'm reading it wrong or it doesn't give a cubic ft spec.
Specs:
Voice coil dia. 50.8/2
Impedance ohm dual 4
FS Hz 37.5
Qms 5.5
Qes 0.5
Qts 0.58
Vas 44.5
MMS g 124.1
Xmax mm/in 11/0.43
SPL dB/m 88
BL TES A-1 17.2
Max power 600w
RMS 400w
Sent from my SM-G935V using Tapatalk
Specs:
FS Hz 37.5
Qms 5.5
Qes 0.5
Qts 0.58
Vas 44.5
MMS g 124.1
Xmax mm/in 11/0.43
SPL dB/m 88
BL TES A-1 17.2
Max power 600w
RMS 400w
I can design you a box if you want.
Most 12" AB woofers will work in 2-2.5 cubes. Even 1.75 for applications like a series 6th order, depending on power levels.
Tune anywhere from 32-35 hz. I like a little lower tuning like 32 hz. Port area depends, I'd have to model it up. Wouldn't need a lot with only 400w power rating.
Yea any help would be great. I couldn't find much online about box size. And I've seen all kinds of reasons for different tune specs. I'm running a skar 800.1 on them and they are in a hatchback. They sound good in the prefab box I have but I want to go ahead and build a custom box.
I sent you a PM
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Jhicks
Jhicks
Henderson NC
Buck
Decebal
    Jun 10, 2024
