BoX Size?
internal volume : like how do i mesure this so i know how to make my box
net internal volume: how do i find out the internal volume??
F3, Qtc : 49Hz, 0.7 and how do i make my box to this mesurment?
what is the differnce between net and just internal volume?
volume is found by multipling (LxWxH) / 1728...dividing by 1728 will give you the cu'. to fint the internal, measure the inside of the box. if you can't get the inside of the box, measure the outside and subtract the thickness of the wood on both sides.....
example: if i have a box that is 14 x 14 x 16 externally and it's made from 3/4" mdf, then i would subtract the wood from each side (since .75 +.75 = 1.5) so now i get 12.5 x 12.5 x 14.5 = 2265.6cu" / 1728 = 1.31cu'.
the net would be after all displacement is accounted for...subtracting the volume of any bracing and the sub itself.
Da64u
Da64u
Fort Lauderdale, FL
Trixter
